I have a pretty simple smoke simulation. Its a room that gets filled, with some turbulence to make it spread.
The problem is that when I change the number of cells from 5 million to 50 million, the simulation changes. Suddenly it seems that the turbulence has much less effect, and even less smoke overall. The difference is pretty big too ...
Is this simething you know the cause of, or do I need to describe the scene in more detail?
