Hi we have a small scale scene even with gravity set at 0.7 liquid moves really fast. SPF are set at 18. Do we need to change time scale? If yes then why - all proportions are correct. Thanks
Why does liquid move so fast
Originally posted by George Barzinski View PostHi,
Perhaps the Scene Scale is too small. Set the gravity back to 1.0 and increase the Scene scale several times.
Btw, if you want to make the liquid particles not slide wildly on the geometry, you might enable Wetting, set the Consumed Liquid option to 0 so liquid particles don't try out when leaving a wetmap, and boost the Sticky Effect option to a high value. You will need to dial in a very very small value for Viscosity in order to make this work, so it's a bit of a hack..Svetlin Nikolov, Ex Phoenix team lead
