hardware bench
  • #31
    Here you will find chart and a scene. My xeon is like 10core at 4.7. Compare to phx results Maybe it is very bad max architecture, that limits phx. Dunno.
    https://www.vfxarabia.co/post/houdin...kspeed-updated
    CG Artist
    • #32
      Originally posted by Syclone1 View Post
      In phoenix the TR4's cant compete but in rendering its another story as my TR4's are substantially faster at rendering than my 9900k. Everything has its use and in most industries you can use two or more similar tools to do the same job, and generally one tool will be more efficient than the other at certain jobs...
      yes, that's why I found that the TR 2950X was good choice (high clock speed). It might not be the fastest in sim, but it does a good job when rendering. So, when you have to do both, it's a good alternative for a good price.
      www.mirage-cg.com
      • #33
        Code:
        CPU AMD RYZEN 3900 4.1Ghz [24 threads]
        RAM
        Total elapsed
        11m 37s
        Performance
        3.38 vox/s
        CG Artist
        • #34
          My new homepc
          Code:
          CPU AMD RYZEN 3960x 4.2Ghz [48 threads]
          Total elapsed
          9m 07s
          Performance
          4.40 vox/s
          CG Artist
          • #35
            Might as well revive this thread with the launch of the AMD 5000 series!
            Code:
            CPU AMD RYZEN 5950x 4.875Ghz [32 threads]
            Total elapsed
            9m 47s
            Performance
            4.45 vox/s
            RAM is 4x32GB (128GB) Corsair LPX 3600c18 running at 3600c16, I think there is more headroom in this RAM for overclocking but haven't got around to it yet, I wanted to confirm this was stable first. Manually setting the 1.8v PLL to 1.8v dropped my time and performance by a lot (15m 43s, 2.67M vox/s) but bumping it up incrementally gave significant performance uplift, right now it is at PPL 2.05v for this score. PBO is enabled on the CPU, I see single core hitting 5ghz briefly. FCLK 1800mhz for 1:1.
            Saving to an SSD with compression disabled.
            Click image for larger version  Name:	cachemem_3600c16.png Views:	0 Size:	117.9 KB ID:	1092162
            • #36
              Interesting. Which version u used ? Gonna retest, since u hit me with performance, but more total time.... Gonna retest Thos l3 speed is quite boosted. Kewl. And what temp was ?
              CG Artist
              • #37
                5950x looks pretty decent for a workstation / sim box with a fast gpu
                • #38
                  I used 4.20. After a bios update that came out a few days ago I don't have to mess with the 1.8 PLL and push it beyond 1.8v anymore and I've been working on tightening up my DRAM timings to reduce the latency too but its not as easy with 4 sticks of duel rank high capacity memory. Here is my new score:
                  Code:
                  Total elapsed
                  9m 30s
                  Performance
                  4.57 vox/s
                  Temps didn't go above 77c (I have a waterblock on there).
                  • #39
                    Todays nightly. 4.30
                    Code:
                    Total elapsed
                    9m 27s
                    Performance
                    4.76 vox/s
                    CG Artist
                    • #40
                      Hi Guys,
                      Did any of you test already a 3970X or 3990X with Phoenix (simulation and rendering) ?
                      www.mirage-cg.com
                      • #41
                        Tested with the Car tire burnout scene for 3ds Max and Maya with the Preview disabled during simulation.
                        Link to the 3ds Max scene - https://docs.chaosgroup.com/display/...Cartireburnout
                        Link to the Maya scene - https://docs.chaosgroup.com/display/...CarTireBurnout
                        Code:
                        AMD 3990x 128 threads @ 4.0 GHz
                        Memory 3400 mhz
                        SSD Samsung 970 EVO Plus
                        3ds Max - 4.30.01 Nightly, Build ID: 2020112730466
                        [B]Total Elapsed 10 min 22 s[/B]
                        Maya - 4.30.01 Nightly, Build ID: 2020112730466
                        [B]Total Elapsed 22 min 10 s[/B]
                        And the next one
                        Code:
                        AMD 3970x 64 threads @ 4.23 GHz
                        Memory 3200 mhz
                        [B]Total Elapsed 9 min 36 s[/B]
                        [B]Total Elapsed 19 min 46 s[/B]
                        Georgi Zhekov
                        Phoenix Product Manager
                        Chaos
                        • #42
                          Errr... reassure me.... maya and max scenes don't have exactly the same settings, right ? Or do I have to ditch Maya ?
                          We might have discussed this already, but I'm not sure...
                          www.mirage-cg.com
                          • #43
                            hehe, no worries, whoever ported the scene just did something for Maya without taking care of equalizing the settings.
                            • #44
                              As an addition - there is no reason for simulations in maya to be any different in speed versus Max. There are some additional thing that might differ between Max and Maya and be faster in either - texture sampling, talking with particles and with forces, and the previews, which are often faster in Maya.
                              • #45
                                Thanks a lot Svetlin. It's nice to hear that sometimes, something might be faster in Maya
                                I'll do the burnout test to see how my workstation behaves compared to the 3970X and 3990X.
                                www.mirage-cg.com
