phoenix FD 4 + backburner
  • phoenix FD 4 + backburner
    I´ve just installed latest phoenix, and my slaves won´t render any simulation. it says MISSING Phoenixfd.dlr.
    I have installed it as an standalone slave.
    previous version worked fine.
    thanks!
    Surrealismo
    https://www.facebook.com/surrrealismo
    Hey, does it help if you make a workstation install?
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      yes, it worked. is that the way to install on render slaves?
      Surrealismo
        Hey, so there are 3 installation types - we recently renamed them so hopefully they are more intuitive this way: https://docs.chaosgroup.com/display/...ionofPhoenixFD
        If you install only as a V-Ray Standalone render slave - you would only be able to render using V-Ray standalone - phoenixfd.dlr will not be installed.
        For a Backburner slave, you gotta install the second option - simulation and render slave. This is needed in order to both simulate and render in 3ds Max - even though rendering would not need a license, you still gotta have the dlr.
        In case you are already using the 2nd option and are installing as a sim+render slave, please let me know, so we can double check if everything is fine.
        Cheers!
