correct way to make an infinity pool
  • correct way to make an infinity pool
    hi, How you guys deal with this kind of pools? What would be the ideal setup on phoenix?
    thank you!
    Surrealismo
    https://www.facebook.com/surrrealismo
    Hey,
    If you want your pool to be dynamic ( if you want to splash some objects or more water inside of it) - you can take a look at this tutorial and follow the same approach - https://docs.chaosgroup.com/display/...ith+Containers
    If you don't need splashes or liquid interaction you can just make a regular plane and use the Phoenix Ocean texutre as a displacement.
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      oceantex on the top surface, animated texture for the vertical portion and the base 2 oceantex's masked with a gradient ramp so the one closer in is a little more agitated. if your camera isnt inches away from the edge this will be fine - and if it is, just use a super fine grid and dont simulate the entire thing.
        does the plane with oceantex has to have thickness? I allways do it without thickness, but I think I´m getting strange Refraction results. Take a look a the images, the one without thickness, cuts the ball at the moment intersects the water.
        thank you for your input!
        Surrealismo
          Indeed in order to get a correct refraction you need some thickness.
          Georgi Zhekov
          Chaos
            1 cm thickeness or the same size as the pool´s depth?
            Surrealismo
              Depends on the result you're after, but the picture you shared above with the thickness seems good to me.
              Georgi Zhekov
              Chaos
                I´m trying to get as much realistic as possible.
                Surrealismo
                  Having the real thickness should give you proper results, note that the thickness also affects the fog color of the refraction. You can find more about how refractions work here - https://docs.chaosgroup.com/display/VRAY4MAX/VRayMtl
                  Georgi Zhekov
                  Chaos
                    thank you georgi
                    Surrealismo
                      Leo did you manage to get a reasonable result for this? The reference images you posted are exactly what I need to replicate at the minute
                      DAVE BUCKLEY
                      www.daveandco.co.uk
