Phoenix Wet-Map (Particle Texture) not rendering wet-material...
  • Phoenix Wet-Map (Particle Texture) not rendering wet-material...
    Hello guys,
    I do have a setup like this:
    Vray Blend material with dry material as base 1, wet material as coat 1 and Phoenix particle texture map as wet-map in blend 1 slot
    Prior to this when setting up the particle texture material I did slect the Phoenix wetmap particle of my Phoenix liquid sim. So I think this is how it´s all done.
    When rendering (CPU or GPU) I cannot get the wet material to show.
    My liquid simulation was simulated with wetmap enabled and I do have lots of "red wet particles" in the particle preview.
    Any help appreciated,
    thanks,
    Martin ;=)
    Hey,
    It will certainly not work on GPU... yet. We are yet to implement the particle texture for GPU.
    However, for V-Ray CPU it should work. Are you setting up your material like this?
    https://docs.chaosgroup.com/display/...ndwetmaterials
    Here you can grab a scene with a ready setup too:
    https://docs.chaosgroup.com/display/...nes-Beachwaves
    Cheers!
      Try to put simple checker map in the blend mask slot, if it works, the reason is the particle texture setup, if not - the blend material setup
      If the texture is to blame, put it as diffuse texture in a simple material, and see how it appears
      ______________________________________________
      VRScans developer
        Hello Svetlin, hello Ivaylo,
        thanks for the reply - I was abloe to investigate and fix - GPU compatibility I had not been aware of and also I had a mistake in my setup and now it works!
        Cheers,
        Martin
