I did. And I can select the TyFlow system. But there is no "event" to pick and that means it would read the entire particle system. And you had Phoenix version3.14?
I just created a default standard TyFlow system. Tested both with the cube geo and without just having particles.
When the particle interface is enabled, Phoenix uses the whole particle system. If you want to use only a specific event - you can use the Export Groups in the Particle Groups operator to define which particles the interface to export.
You can check how this works in our tutorial here - https://docs.chaosgroup.com/display/...me+with+tyFlow
Thanks. I got it to work. Not sure why but I probably messed up the default flow and had a hårt time identifying the issue. Now it works as expected.
Thanks for taking the time.
