PhoenixFD blend material unlinked everytime file loads
  • PhoenixFD blend material unlinked everytime file loads
    I've set up a Vray blend material to be able to mix 2 different fluids together (via the PhoenixFDTexture Node), but every time i reload the file from a new session of Maya, the PhoenixFDTexture node and the 2nd material are unhooked/unlinked from the VRBLNDMAT.
    I have to run a small bit of melscript to relink them, but i need to render on a farm and would rather not attempt to run a script on file load to fix for each instance.
    Any known reason why this might be happening and how to properly fix it?
    thanks
    I'm using Maya 2018.3, Vray 3.60.04 and Phoenix 3.14.
    and here's the code i have to run to relink the shader back together.
    //script to reconnect nodes to Vray blend material
    connectAttr -force Clear_VRMAT.outColor Liquid_BLNDMAT.base_material;
    connectAttr -force Clear_VRMAT.outColor Liquid_BLNDMAT.coat_material_0;
    connectAttr -force PU_Ebony_Wet_PU_Ebony_Wet_VRMAT.outColor Liquid_BLNDMAT.coat_material_1;
    connectAttr -f PhoenixFDTexture1.outColorR Liquid_BLNDMAT.blend_amount_0R;
    connectAttr -f PhoenixFDTexture1.outColorR Liquid_BLNDMAT.blend_amount_0G;
    connectAttr -f PhoenixFDTexture1.outColorR Liquid_BLNDMAT.blend_amount_0B;
    connectAttr -f PhoenixFDTexture1.outColorB Liquid_BLNDMAT.blend_amount_1R;
    connectAttr -f PhoenixFDTexture1.outColorB Liquid_BLNDMAT.blend_amount_1G;
    connectAttr -f PhoenixFDTexture1.outColorB Liquid_BLNDMAT.blend_amount_1B;
    Hey,
    Can you try the latest Phoenix 3.14 nightly here: https://nightlies.chaosgroup.com/#/phoenix3max/20201223 and see if it makes a difference?
    Cheers!
      Hey,
      Can seem to reproduce it here. As these are quite old builds, if possible can you try if you update to V-Ray 3.60.05 and get the latest 3.14 nightly build, does it resolve the issue?
      Here is how to get a nightly - https://forums.chaosgroup.com/forum/...nightly-builds
      If updating the builds doesn't solve it can you send over the scene?
      Thanks!
      Georgi Zhekov
      Phoenix Product Manager
      Chaos
