PhoenixFD freaks out with any modifier asigned to it
  • PhoenixFD freaks out with any modifier asigned to it
    Hello,
    I have a weird behavior with phoenixFD and a modifier and rendering in vrayGPU
    (I posted in the vrayGPU section already, as I wasnt sure what could cause the problem...)
    Here now I tested a bit more.. and this also happens with a turbosmooth asigned to the PhoenixFD object.
    the first frame always renders fine, but all the others get messes up. Strange thing is.. it even is visible in the viewport then !
    it only get clean, after I move the time slider.
    Please look at the video I recorder on youtube: https://youtu.be/E_nBn3rMbjg
    MBA Studios | 3D Images & Visual Effects
    Hey,
    Thanks a lot for the report. We reproduced the issue and logged it in our bug-tracking system.
    Will update the thread once we have something.
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      Thank you for the quick response.
      I found a workaround in the meantime. When you cache the PhoenixFD with alembic, you can use all modifiers without any issue.
      Is it an additional step, but works as a solution for now.
        Hey, just wanted to let you know that the issue should be fixed in the latest Phoenix nightly builds.
        Here is how to get one - https://forums.chaosgroup.com/forum/...nightly-builds
        Cheers!
        Georgi Zhekov
        Chaos
