Increasing Grid resolution resizes my simulation grid
  • Increasing Grid resolution resizes my simulation grid
    Did something change in Phoenix 4?
    When I increase or decrease the resolution of my fire grid, it resizes the grid box but does not change the total cells. The old way I was used to was setting the dimensions of the grid, then increasing cell size to adjust for resolution.
    It's difficult because every time I change the resolution I have to resize the XYZ dimensions of the grid .
    Did this change or is it my 3dsmax settings? I'm using 3dsmax 2022 and Phoenix 4.41
    Thank you!
    Cyril
    Hey,
    This is a known issue with 3ds Max 2022 that happens after you merge a scene. It is fixed in the Phoenix nightly builds.
    Here is how to get one - https://forums.chaos.com/forum/phoen...nightly-builds
    Grab the latest nightly and it should work correctly.
    Cheers!
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      Something got reset in my 3dsmax since I posted this, and it seems to work normally now.
      Thank you for pointing that out!
