Hey, could you share more info about the problem? Is this a fire/smoke simulation or a liquid simulation? Could you screenshot the scene, or the settings rollouts of the Simulator? Or even better - could you send the scene over so we can check it?
Ah, I just came here to write that I could not break it here either
Here is the option:
If possible, please send over the Phoenix log in case it happens again - it should contain more info about what went wrong. You would be able to open it from the Phoenix FD menu -> Preferences... -> Open Log File Location.
If possible, could you install the latest nightly and run the simulation with Max Memory % enabled again, and if the issue still occurs, could you send the log file once again?
