Help: BAKE to Texture loses specular
  • Help: BAKE to Texture loses specular
    I understand that specular refection's are view dependant. Its not obvious how to bake them into a texture map
    The left image shows a render of the baked texture map and the right images show what the render 'should' look like
    Specular refection's are lost in the baked textures (vRayCompleteMap)
    There are no options ( as far as i can tell ) to specify a camera when rendering to texture​ . So how do I fix this ? I can bake reflections in Arnold but rebuilding the scene will change the look
ID:	1178822Click image for larger version
    My website with free maxscripts and tutorials |
    Hi, thanks for posting. This difference is most probably due to the camera angle. Baking is done trough a different camera to what you are rendering your image and the speculars are different/lost.
    You can bake from a specific camera using this script:
    renders.current.camera_bakeCamera=
    Vladimir Krastev | chaos.com
      thanks! but doing these leads to strange black/ dark artifacts on the edges of the objects. is there any way to fix this? I've attached these examples here Click image for larger version
ID:	1197717 Click image for larger version
