Originally posted by luizfernando_fonsecapimentelView Post
2. Should I increase or decrease the size of the voxels?
Indeed, by "increasing the grid resolution" I meant pressing the "Increase Resolution" button. However, you seem have quite high resolution already.
Could you please show me your viewport from the top view? Are you sure that your simulator is not too wide or too long? Maybe you can shrink it to make it shorter and narrower, so you can have more grid resolution and more details.
Cheers!
Yes, my simulator is big, because I need to show a big track in the video I'm going to make.
Can I decrease the size of ocean particles even with a large grid?
Beware that this might change the way the foam trail looks like, but it's worth trying as it will reduce your resolution tremendously. Try to set the Max Outside Age of both the Foam and Splash to a large value (in seconds), such as 30 or 60, and then make the grid short like this:
And then, if the simulation looks okay after these changes, then you could increase the grid resolution in the Grid rollout so the droplets would be smaller.
