Submitting to Deadline Maya Phoenix
  • Submitting to Deadline Maya Phoenix
    Has anyone ever run into this error when submitting to deadline?
    Error: V-Ray error: ERROR: Could not create plugin PhoenixFDCache !
    I ensured I installed the correct Vray versions and Phoenix to the computers. Keep getting this error.
    Hello,
    Looks like a problem with the installation. How about if you try and run a test simulation locally on the machine without Deadline - does this work?
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      I have Phoenix installed on 2 machines, and I tested rendering both locally and they output the images fine.
      Those 2 machines are also on deadline as workers.
      When I submit to the deadline and only use those two machines, I get that error.
      There was no error during installation, so I am not sure why that came up.
        Can you send us the full logs from the workers? Also is this error showing up when you are only trying to render through Deadline or you try to simulate and render via Deadline?
        Thanks!
        Georgi Zhekov
        Chaos
          I attached the full worker log, both pc has this same log.
          This error only shows up when i render through deadline, not simulate via deadline.
