Phoenix won't simuilate
  • Phoenix won't simuilate
    hi all
    i had a big problem trying to simulate some smoke in a closed object in a specific scene.
    so i testet it in a diferent scene beacause i thought the scene might just be to big (meanig too many polys), but it all worked fine.
    so i found out that i cant simulate in a sphere (4 example) when the normals point outside, but that it works fine when they are fliped (pointing inside).
    just wanted to communicate that, beacause i needed a lot of time to found out
    now im struggling a bit with the tweaking to get some smoke without fire, so if you got any tips that would be great!
    but over all phoenix is a great tool, it got just a bit of a challenging learning curve
    best regards
    MathTheRender
    emoticom AG
    www.emoticom.ch
    Regarding smoke without fire a quick run-down:
    -Set temperature to a meaningful value (if you want hot smoke, make it hot, if not...well then not :P)
    -Turn on the smoke channel in the output options
    -in the rendering options turn off "emmission" to get rid of the rendering of fire based on temperature
    -use the transparency and diffuse settings in the render options to tweak the look of the smoke
    Regards,
    Thorsten
      no need to use the smoke channel, the temperature based solutions run slightly faster and consume less ram. just disable the emission and lift up the opacity diagram.
      VRScans developer
        Good to know!
          thanks guys!
          your tips gonna help me get into the logic of Phoenix much more faster!
          best regards
          MathTheRender
          emoticom AG
          www.emoticom.ch
