Ripple effect in Smoke
  • Ripple effect in Smoke
    Currently I'm messing around with phoenix to get a better understanding, yesterday while playing with the smoke settings I notice small ripples (Hope I'm using the right word for it) in my render.
    Does this effect happen because of wrong render setting or sim settings?
    Using ir/lc as render method.
    Cheers,
    Oliver
    https://www.artstation.com/mokiki
    seems like light cache artifact. make single rendering without light cache for test
    ______________________________________________
    VRScans developer
      because I'm an idiot I accidentally overwrote the file so I have a slightly different light setup but the artifacts are still visible without light cache.
      Cheers,
      Oliver
        Lightcache in phx rendering rollout.
        I just can't seem to trust myself
        So what chance does that leave, for anyone else?
        CG Artist
          hm, does not seem to be the light cache, well can i see the scene?
          send it to phoenix@chaosgroup.com
          VRScans developer
            Turned off LC inside the phoenix render rollout
            ripples still there. Only difference much longer render time.
            @Ivaylo
            I send you the file.
            Cheers,
            Oliver
              yes, i expected that after you second shot, because the LC artifacts appear only in very dense smokes, but the smoke above is not dense.
              i have one question - is this the cell size? because the rest smoke looks detailed, or it's just displacement?
              VRScans developer
                If I understand your question correctly than yes I think it's mostly displacement.
                Cheers,
                Oliver
                  well, this is a bug in the displacement algo (affects only the new volumetric displacement that was introduced the last release)
                  i made two shots of frame 13 to show the difference.
                  VRScans developer
                    Is there an chance the bug will be fixed in one of the next releases of phoenix? And thanks again for your responses.
                    Cheers,
                    Oliver
                      yes, it's fixed already, the second image shows the render result after the bug was removed.
                      VRScans developer
                        Ah thanks for the clarification.
                        Cheers,
                        Oliver
