Parsing Results
  • Parsing Results
    I often find that creating simulations from scratch there is nothing visible in the render or preview even though the cache is created. Any tips on maximizing visibility or troubleshooting?
    liquid simulations i guess?
    ______________________________________________
    VRScans developer
      Mostly smoke and fire
        the default settings prefer exactly the smoke and fire, no idea how this happens. could you send us a scene?
        VRScans developer
          Have sent it.
            the interaction list was set to include, and the source wasn't inside. one more thing - no need to set the wind as modifier, just add the force field as scene object.
            VRScans developer
              Thanks. The wind should be in the include list and that is all that is needed?
                Also does the source object need to be explicitly added to the include list?
                  you mean the source geometry? if you need interaction with it - yes. otherwise it will emit in inject or brush mode, depends on the source settings.
                  VRScans developer
                    In the test file, where the source geometry was not in the include list, why wasn't there an emission in inject mode?
                      in the test file the source helper wasn't in the include list.
                      VRScans developer
