Hair & Fur lighted with phoenix
  • Hair & Fur lighted with phoenix
    Hi there!
    I'm trying to render a fury caracter (with hair & fur) holding a torch made with phoenix. (see screen 1)
    We made phoenix with an additional light and result is really convincing, BUT when we render the scene with modifiers Hair&Fur it crash all the time.
    I even can reproduce this bug with a teapot with low fur.
    In doc, it is said that additional lights shouldn't be used when using GI... why ? how do you project light fire when using GI ? you fake it with a omni ?
    We use brute force / light cache because of the vrayHairMaterial, one caracter is made with ornatrix, and it's working great.
    Simulation has been made with Phoenix 2.0, i've tryed to render with 2.1 but looks like it's the same.
    Have you ever try phoenix + hair&fur ?
    thanks !
    -pingus-
    http://www.tatprod.com/
ID:	877767Click image for larger version
    http://tatprod.com/
    Look likes it's on render end, when cleaning RAM that the crash comes.
    [2013/J/26|12:20:57] RenderAtTime() done.
    [2013/J/26|12:20:57] Stopping frame timer.
    [2013/J/26|12:20:57] Total frame time: 5,8 s
    [2013/J/26|12:20:57] Render() done.
    [2013/J/26|12:20:57] Entering Close()
    [2013/J/26|12:20:57] Calling endSequence().
    [2013/J/26|12:20:57] Entering endSequence().
    [2013/J/26|12:20:57] Calling renderEnd().
    [2013/J/26|12:20:57] Calling renderEnd() on render materials.
    [2013/J/26|12:20:57] Unloading bitmaps.
    [2013/J/26|12:20:57] Freeing render instances and lights.
    [2013/J/26|12:20:57] Sending RenderEnd().
    [2013/J/26|12:20:57] Sending RenderEnd() to atmospheric effects.
    [2013/J/26|12:20:57] Sending RenderEnd() to render effects.
    [2013/J/26|12:20:57] Sending RenderEnd() to the tone operator.
    [2013/J/26|12:20:57] Sending RenderEnd() to environment maps.
    [2013/J/26|12:20:57] Sending RenderEnd() to override mtl.
    [2013/J/26|12:20:57] Broadcasting NOTIFY_POST_RENDER.
    [2013/J/26|12:20:57] error: UNHANDLED EXCEPTION: Broadcasting NOTIFY_POST_RENDER
    Last marker is at ./src/vray.cpp, line 425: VRay::freeData(), clearing render settings.
    http://tatprod.com/
      this is an old recommendation, i will check if is still in the documentation but it's no longer valid. the reason for it was the double lighting of the scene when GI is used. now you can use GI with additional lights, even the sample scenes use it.
      can you send us a simple scene, that reproduces that produces the crash?
      VRScans developer
        Sure, here is my scene test :
        http://tatprod.com/Bug/Phoenix_fur.rar
        Light is not active on the phoenix, but when i check it, it crashs
        http://tatprod.com/
          no crash here
          can you send me the log file of phoenix after a crash? the log file is in documents/phoenix fd
          edit: we reproduced it, i hope we will able to find a workaround for you
          VRScans developer
            the bug is fixed, but can't find a workaround, i would recommend to download the tomorrow's nightly build
            VRScans developer
              ok, we can wait 1 or 2 days, let me know when the build is ready (and where i can found it)
              thanks !
              http://tatprod.com/
                Any news from lighting H&F ?
                http://tatprod.com/
                  I can see an issue "crash with hair and fur lit by phoenix vray light" that is marked as fixed for the nightly builds on the 27th. Does that help?
                    You should ask the support team to grant you access to the Phoenix nightly builds
                      contact the support for the details how to download the nightly builds, i think you already have access.
                      VRScans developer
                        ok thanks all !
                        http://tatprod.com/
