I have a really simple setup. See attached image.
There is just some scattered ticks, that have a gradient ramp texture animated from left to right. I'm using that map as a Temperature map in PHXsource for the ticks.
When I try to simulate, everything kinda stops after few frames. The temperature moves with the map, but there isn't any "fluid" movement after that. If you turn the smoke on, you can see the freezing effect better.
File attached.
Syttyminen.zip
Max 2012 x64, vray 2.40.03, Phoenix latest nightly from today and earlier 2.10.10
File attached.
Syttyminen.zip
