sim suddenly starts writing 5kb cache frames
  • #16
    alright - i'll prep and email it. thanks!
    • #17
      As soon as the nightly builds are back online - hopefully today or tomorrow, there is a fix there you can try and say if it makes any difference.
      • #18
        great thanks! will do.
        • #19
          if you still need the scene, i'll be able prep and put it up tomorrow. i'm in PST. thx again.
          • #20
            tomorrow is good, thanks for the collaboration
            ______________________________________________
            VRScans developer
            • #21
              Hello, the nightly builds with the attempted fix are out, can you try if it makes a difference? (most max versions are in the folder of Oct 21st)
              • #22
                surely - will do. thanks a ton!
                • #23
                  finally got a chance to test it out. the problem still persists, however this time I did receive an error message upon write of the 1st 5kb frame. i'm currently using v25087. thanks!
                  • #24
                    Seems like you can't write files over 32MB over the network. We will add a fix for this, but just for the sake of clarity - what OS do you use, and can you save anything else big from 3ds max, for example a vray proxy or some GI map, anything over 32 megs?
                    • #25
                      yes, the number 32 sounds like a good value for a hidden limitation. we will try to workaround it, but would be very good to know what is causing it.
                      VRScans developer
                      • #26
                        hi, thanks very much! these boxes are winXP x64 (don't laugh). yes, the boxes write all other caches fine: fumefx, vray gi maps, TP cache data, etc. thx again!
                        • #27
                          Copy that, the docs say that xp 64 has issues over 32 megs, we will add a workaround.
                          • #28
                            i'm also with xp64, never had such a problem, but if this is an official info, there is no doubt that this is the problem and we will workaround it
                            VRScans developer
                            • #29
                              this is great news guys - that is to have a 'known' issue that could be causing it. thx so much for looking into a workaround!
                              • #30
                                Hello and sorry for the long delay - in today's nightly build we added a fix that will hopefully deal with this problem. Since we can't test it here, we're counting on you to try it out
