floating foam
  • floating foam
    I am getting a lot of instances of foam particles floating in the air or drifting slowly downward without any inertial effects from the sim.
    Any suggestions why this may be happening?
    perhaps your simulator is too big, and the default speed of falling is too low compared to it. can you share more info, the cell size, the falling speed of the foam, the foam size...
    ______________________________________________
    VRScans developer
      cell 35cm x 5,000cm y 17,000cm z 900cm
      foam size 10cm
      rising speed is 1cm (oddly low since the particles tended to just keep flying upwards)
      falling speed 1000cm
        Would it be possible to send us your scene to investigate further on this foam issue? You can send the file directly to support@chaosgroup.com or post then here.
        Also let us know the exact Phoenix build that you are using.
        Tashko Zashev | chaos.com
          I could probably reproduce it faster than I could find the file, but I'm not going to be in the office for another week. I'm using 2.2 rev 24510
