perhaps your simulator is too big, and the default speed of falling is too low compared to it. can you share more info, the cell size, the falling speed of the foam, the foam size...
Would it be possible to send us your scene to investigate further on this foam issue? You can send the file directly to support@chaosgroup.com or post then here.
Also let us know the exact Phoenix build that you are using.
