Procedural Noise Map
  • Procedural Noise Map
    I'm getting repeated crashes when using procedural noise in the discharge map slot. Testing it on the plane sample file, can send if needed.
    Yes, we will need the file, couldn't reproduce it with all default settings and a cube emitter.
      hmmmm, I just did some more testing - it may not be the noise but that file definitely has a bug in it as it still crashes without the noise map active. Simulates about 10-20 frames then crash....
      Could it be related to how the proc is mapped? channel, xyz object or world perhaps?
        send us the scene and we will find the reason in few minutes
        VRScans developer
