underwater explosion foam issue
    I just tried to render the first frame after setting the cache start to -30 and nothing renders. The same thing happens when I change the play start to 30 (which seems to be the same thing as cache start to -30)
    Regards
    Steve
    My Portfolio
      Just realised I need to tick "load nearest possible".
      Regards
      Steve
      My Portfolio
        Well. That didn't work. It does the same thing with the latest nightly.
        It also does the same error on render nodes.
        Regards
        Steve
        My Portfolio
          You have to set "Play Start" to 30, if you want the simulated caches to start playing from frame 30 on the timeline. Check the help file here: http://docs.chaosgroup.com/display/P220N/Input
            Thanks. I got that sorted. Still have the issue with the error. Is anyone looking at this ? Sorry to push but I need to let my client know what is happening and if they are likely to get the render tonight ?
            Regards
            Steve
            My Portfolio
            • #21
              We managed to reproduce it, but still looking into it... The crash happens at the end of the rendering, is that correct?
              • #22
                That's right.
                Regards
                Steve
                My Portfolio
                • #23
                  Okay, could you try the following:
                  - Open the environment and effects settings and delete the VRayVolumeGrid atmosphere.
                  - Save the scene and restart max.
                  Try rendering again. There is an issue we'll try to fix in the coming nightly builds, but for now this workaround should help you continue your work.
                  • #24
                    That is working now. Thanks a lot !
                    Regards
                    Steve
                    My Portfolio
                    • #25
                      Good luck!
                      • #26
                        Alrighty, the volume grid issue is fixed - if you have access to the VRay nightlies, tomorrow's nightly should work fine.
