Render crash on irradiance map prepass.
  • Render crash on irradiance map prepass.
    Hi!
    I have a problem rendering my scene if there's anything other in the scene then the simulator. If I put any object under water, so refraction comes into play, the irradiance map pass crashes with an "unhandled exception error".
    I use vray version 3.20.03
    Phoenix nightly build 26171
    Windows 64 bit with 3dsmax 2016 64bit.
    Any suggestions what might cause the problem?
    from the vray log:
    [2015/Aug/30|11:45:19] Setting up 8 thread(s)
    [2015/Aug/30|11:45:27] Threads completed
    [2015/Aug/30|11:45:27] Merging light cache passes.
    [2015/Aug/30|11:45:27] Setting up 8 thread(s)
    [2015/Aug/30|11:45:27] Light cache contains 9314 samples.
    [2015/Aug/30|11:45:27] Light cache samples collected; compiling lookup tree.
    [2015/Aug/30|11:45:27] Light cache takes 5.2 MB.
    [2015/Aug/30|11:45:27] Prefiltering light cache.
    [2015/Aug/30|11:45:27] Average rays per light cache sample: 33.65 (min 1, max 1059)
    [2015/Aug/30|11:45:27] 1 interpolation maps registered
    [2015/Aug/30|11:45:27] Rendering interpolation maps with minRate=-4 and maxRate=-3
    [2015/Aug/30|11:45:27] error: UNHANDLED EXCEPTION: Irradiance map thread
    Last marker is at ./src/globillummap.cpp, line 1932: GlobalIllumMap::buildLightMap() {5}
    can you attach a scene for max 2014?
    ______________________________________________
    VRScans developer
      Hi! Thanks for your reply.
      Here goes the scene.
        If I create any object that is behind the foam, it crashes. Normally the ocean bed is there, but that is not included in this scene. But you can just create a sphere and it already crashes it.
          thanks for the scene and the detailed description of the problem conditions, hopefully tomorrow we will fix it.
          VRScans developer
            any progress on this one?
              no at all. the scene does nothing, ther is no movement, no foam is born, nothing to render. can you send us a cache file that produces the crash?
              VRScans developer
