and perhaps the last try, trying possible solution, the bug is very probably localized , built sent
Complete crash.
Originally posted by Ivaylo Katev View Postand perhaps the last try, trying possible solution, the bug is very probably localized , built sent
Opened the scene, and only took the grid size down to 2m. It crashed at frame 1.
EDIT1: Dissabled the foam, and it simulates fine.
Let me know if you need the log file again.
EDIT2: Trying to get it to crash now without foam enabled. So SPF down to 1, and I'm gonna play with splash/mist settings to rediculous settings to see if it only crashes with the foam on.Last edited by oophus; 22-10-2015, 08:21 AM.
Originally posted by Ivaylo Katev View Postyes, send the logfile of build 4
Btw. The mesher is still producing the strange result as seen here:
Build 5 crash log file.
EDIT1: Tried to sim again without foam, and it sims through. Putting on the foam again makes it crash.Attached Files
Originally posted by Ivaylo Katev View Posti see! ok, i will see it after this crash is found, looks like an easy problem
On SPF 1 it crashed as usual.
Here is the log file for build 6:
Attached are also the test scene again, as I may have saved after doing alot of stuff in it. But this is the same scene that have produced the crashes for all of today. Only difference is its on 12m cells, and I have put it down to 2m cells and pressed sim.Attached FilesLast edited by oophus; 22-10-2015, 08:56 AM.
Originally posted by Ivaylo Katev View Posti had time to send one more build
i will try to reproduce it in pure scene tomorrow. the crash occurs in the b2b interaction procedure, as workaround you can simulate with b2b=0, for ship scenes it may be even better.
Build 7 is starting as build 6. First sim goes through. So I will try to put the SPF to 1 as usual. If it crashes I will see if putting the b2b down to 0 works.
Build 7 crash log file, after it simmed to 40, restarted and put SPF down to 1, then it crashed.
EDIT: Trying b2b = 0.
EDIT2: b2b = 0 have worked both at 4 SPF and 1 SPF. Trying to up it to 15.
EDIT3: Hehe, I tried to put b2b = 1. It crashed.. ^^
So it looks like you have narrowed it down a fair bit today, thats good.Attached FilesLast edited by oophus; 22-10-2015, 09:15 AM.
