So I'm running a couple tests on making my first Phoenix ocean and ran a test of 100 frames to my farm which currently has 6 dual Xeon's and an i7, everything was running great until I dropped the frames in to AE (After Effects) only to find the frames rendered by the i7 are what I can only describe as out of sync as the waves are different from the rest. I deleted the 15 or so frames and re rendered just those ones on the Xeon's and it came out perfect. Ive gone over the i7 machine several times looking at versions of software and plugins and everything is the same. Could it be that I can not mix the i7 with the Xeons when rendering phoenix scenes?
*EDIT*
Ive gone over the version numbers of all the software and everything is all the same across all of the machines, Phoenix 2.20.00, V-Ray 3.30.04, max2016 (no service packs)
Cheers,
-dave
*EDIT*
Cheers,
-dave
