Foam is dying?
the bigger b2b does the opposite, it makes the foam "harder", perhaps you have to use lower value.
is the baubles decrease in size over time?Attached FilesLast edited by Ivaylo Katev; 19-04-2016, 10:51 PM.______________________________________________
VRScans developer
actually this is the scene that i have started with.
but i was trying to increase the quality.
those are the changes:
cell size - 2.0
steps per frame - 14
time scale - 0.5 --------- so the liquid will pure in a regular speed.
vel.threshold - 95 --------- to get more foam
bubble size - 0.15
distribution - 2000
b2b - 50 ------------- in order to get a foam which is closer to beer foam in its consistency.
surface lock - 1.0 ------------ hoping that it will lock the foam to the liquid surface
well, i will try to describe a general way how to change the settings keeping the general behavior
cell size - you decide the new one, but the change factor is very important, it will be used in the rest of the settings. let call the old/new ratio k, i will use this below
steps per frame - increase by k
time scale - do not change, use the source parameters instead
vel. threshold - increase by k to keep the behavior, but to get more foam you have to use the birth rate, not the threshold
bubble size - it depends on the desired look of the foam, but is highly connected with the bubble count and the foam volume. if you want to decrease the size twice, you have to increase the bubble count (the birth rate) eight times to keep the same volume.______________________________________________
VRScans developer
Originally posted by Ivaylo Katev View Postwell, i will try to describe a general way how to change the settings keeping the general behavior
so i have changed to rate like you said and it looks great!
thank you!
here is a link to the preview:
https://we.tl/grX9XvhqTK
