If I create Liquid Sim, right click to finish creation then delete the liquid sim max crashes
Max 2015 crashes with June 10 built
Hello,
Couldn't reproduce this issue here - first thing that comes to my mind is if you could check your Documents\3dsMax\scenes\Untitled_Phoenix2_frames folder and see if there are any cache files left there from a previous sim.
Would it be possible to save the scene right before you delete the sim and the crash and attach it here? Also - are you using a V-Ray or a defscanline Phoenix build?
Thanks!Svetlin Nikolov, Ex Phoenix team lead
still crashes it is for scanline render I attached video and scene
Also Phoenix tabs are just question marks
Hmm, still can't get it to crash. Will install Octane and try again, could be a compatibility issue.
The Phoenix toolbar is still work in progress - soon there will be icons and the rest of the buttons will function
Will update you on the crash when I find out more.
Cheers!Svetlin Nikolov, Ex Phoenix team lead
