Trying a new install of Max 2017 with Vray 3.40.01 and Phoenix 1606126821 from nightly phoenixFD_adv_22501_max2017_vray_30_x64_26821.
Slaves have same new install of Max 2017 running on trial, same process used for the last few years.
Used same downloaded installation executable used on workstation and all render slaves. Tried with install as render slave then tried as full workstation.
Buckets processed with local host render correctly, but those buckets handled by distributed render slaves are blank, only results are background and other geometry.
Generated sim with UNC server cache location. Made sure server folder is accessible from slaves. Verified share security access and antivirus okay.
Tried sending render job to backburner manager and server on Slave1 using only local host. Slave1 rendered properly. Thinking this might set up the cache folders, I tried again from the workstation using distributed render, but again the buckets processed by Slave1 were blank.
Any ideas? I'm sure I am forgetting something.
