Flickering Foam Phoenix 2.2
  • Flickering Foam Phoenix 2.2
    The Foam here is flickering pretty badly .
    What we have tested..
    disable shadows on the shader and the system.
    disabling back up interval
    gi on/off
    john nelson
    jnvfx.com
    CG Supervisor at Picture Shop LA
    If you are using Bubbles or Splash mode you need to increase the Bounces for those. Try with 5 and increase it if needed.
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      But in general - if you are using 2.2, the upgrade to 3.0 is free and you should definitely do it. There were hundreds of fixed issues from 2.2 to 3.0, including various flickering scenarios with the Particle Shader.
      Cheers!
        I was mistaken. We are on 3.0
        john nelson
        jnvfx.com
          Ah, okay then - so if the Bounces don't help, would you be able to send the scene over to Support so we can check if it's not a bug?
          Thanks!
            thank you for your help, if increasing the bubbles does not help, i will submit a support file. how do i do that ?
            john nelson
            jnvfx.com
              just send the file at support@chaosgroup.com with link to this thread
              Georgi Zhekov
              Chaos
ID:	864519this is an example of what we are seeing even after the requested possible fixes. I will be submitting the file to you guys shortly. thank you for all your help
                Also new Video
                john nelson
                jnvfx.com
                  Thank you! Let's see what these are. Kinda look like bucket artifacts, but not exactly..
                    Did you increase min sub divs to 2 or above. Solves that issue for me when using bubbles.
                    Adam Trowers
                      Could it be possible this is happening because we are Network simulating over a many computers?
                      john nelson
                      jnvfx.com
                        Looks like some buckets are missing? Are you rendering in DR? Do all the machines have access to the cache files?
                        Georgi Zhekov
                        Chaos
                          no we are not using dr. just simulating over a network.
                          john nelson
                          jnvfx.com
                            do you mean in the render globals?
                            john nelson
                            jnvfx.com
                              I meant if you are using more than one machine to render. The results you are getting suggest missing access to the cache but it could be something else.
                              We need to investigate the scene and we'll see.
                              Georgi Zhekov
                              Chaos
