Indeed, I thought initially that it might appear where the foam and the ocean surface intersect, but just in case, can you try rendering it with 'geometry mode' enabled on the particle shader? This could give us some hints about it.
I changed "PHXFoam001" and "PHXFoam002" particle shaders to "Geometry mode" made no improvement to the stepping.
At this stage of the animation there is no "noice" added to the simulation and I guess it could be the undisturbed sim grid that is propagated to the renderd image. And since the upper boats hull is causing more disturbance it is not noticable until later in the animation. notice how the stepping is concentric in shape.
Could it help to simply have the grid shift (rotate in a oscillating manner) to mess up the rythm of the steps?
here without motion blur
I can login to nightlies but there are only old files available. I have contacted support so that they can update my account.
I installed yesterdays nightly build and upped the res of the grid x2. (got myself 64Gigs of RAM)
and latest official Vray.
There is still the same issue with the motion blur creating steps in the wake behind the boat.
Reason: added image
Very interesting - in that case, would it be possible to send the scene or a stripped version in case there are any valuable assets to Support? Btw, is your particle shader in point mode?
More likely it's the way Phoenix passes its stuff to V-Ray, but even if it's not, there's a chance we'd able to work around it. Have to see for certain though
Is there a relation between grid resolution and the amount of particles being generated? As I upres I get alot more. But if I liked what I had. Is there a go to formula to adjust the particle generation?
Absolutely - it's the same as for the fire/smoke simulations - changing the grid resolution would produce very different results. We should add upres resimulation to the liquids like for the smoke and fire. How big is the difference in the particle amount though?
I don't know but it's down to foam amount 10 and splash amount 5. Looks ok.
Don't want to stress or anything but I kind of need to get this gig to the rendering phase. What is your estimate on the time frame for a fix?
You mean for the patterns issue? Not sure yet - the support guys have to come to work Monday so I can have a look at the scene and then I'll be able to tell..
