strange foam bubbles
  • strange foam bubbles
    hi. we are rendering liquid with foam and it looks great but some frames render bubbles around the liquid even though they are not even there. Is it octane problem can you try it in vray. I attached 1 frame of AUR through we transfer thanks https://we.tl/chjpqXZKs9
    it is strange some frames it is ok some are not. We are using older 3.04 version because of octane bug. and foam appears very densely where water touches the sink as thousands of bubbles to the point where renderer barely renders it. Stats say 0 foam. can it be because of we use big box as a fill object? Thanks
      it affects splash too frame 752 is fine and 753 is not
      UPDATE: it maybe octane bug and it looks like wetmap some frames rendered some frames does not. not sure
        Yup, these appear to be the wetmap particles. If you can see them in the preview each frame, but they don't render each frame, then it might be an Octane thing..
