hi. we are rendering liquid with foam and it looks great but some frames render bubbles around the liquid even though they are not even there. Is it octane problem can you try it in vray. I attached 1 frame of AUR through we transfer thanks https://we.tl/chjpqXZKs9
strange foam bubbles
it is strange some frames it is ok some are not. We are using older 3.04 version because of octane bug. and foam appears very densely where water touches the sink as thousands of bubbles to the point where renderer barely renders it. Stats say 0 foam. can it be because of we use big box as a fill object? Thanks1 PhotoLast edited by cb LLC; 21-01-2018, 06:45 PM.
