I wish that it would be possible to control a liquid source by a node object (f.e. a box or any other closed geometry), which volume acts as a specification for the expected amout of liquid which comes out of the source. Additionally a time parameter in frames or seconds says, how long the source may need to drop the required liquid. Then you just have to specify the start frame and the liquid generation will be stopped automatically because of the given values. So the pressure value will be calculated internally. As result i got a clean fill process with the right fill level without a long experimental phase.
I hope it is clear what I want to say
Thanks! - May the source be with you!
![big grin](https://forums.chaos.com/core/images/smilies/biggrin.gif)
