Heya Folks!
Two quick things.
Continuing a sim from a frame other than the start is likley going to come in at some point so probably no need to mention it
Second thing is I'd to add more height to a sim to take into account a later splash that appeared and so I added more z size cells. On restarting the sim, the initial fillup had moved the ocean level up higher than originally set since it's always percent of the original height - would it make sense to make this adjust itself to remain at the same z coordinate level in the max scene and thus have the initial fillup number adapt? (if a sim with z size of 100 and initial fillup at 50 had another 100 units of z height added on, you'd have to change the fillup to 25 to keep it in the same place)
Also of course resimulation won't work with adaptive grids!
Cheers,
John
Two quick things.
Cheers,
John
