Path Force
  • Path Force
    Afternoon
    Would it possible to have the fluid not be affected by the spline when it gets to the end? Basically once it reaches the end it would be affected by normal dynamics.
    Thanks
    Adam Trowers
    Hey,
    Currently not - you could force that behavior by using a low Max Distance and high speed along the spline, so the fluid would be thrown out of the path's range.
    I'm thinking about adding a helper that limits the forces' effect to a certain volume in the nightlies, so this might be helpful to eject the fluid from the spline more properly.
      Yea that could work.. at the moment the high velocity option doesn't work. That's what I tried first time round, it just clumps at the end, almost static. Thanks
      Adam Trowers
        Done a little preview for you Fade start at 1 does the same thing also.
        https://www.dropbox.com/s/os6kt02rw0...force.mp4?dl=0
        Adam Trowers
          Dynamics generally don't work outside the influence of the path force, is that a bug?
          Adam Trowers
            Hmm, can you send that scene over so I can have a look? Thanks!
              There you go
              https://www.dropbox.com/s/cc1g2h4k7k...test_.max?dl=0
              Max 2017
              Adam Trowers
                Alrighty, finally on this issue - so the change which added the option to choose a number of segments changed the behavior of the FollowPath force and in Wednesday's nightlies the original behavior of the fadeout is restored - the fadeout affects the influence, so this way the path force can never set the fluid to its exact values, but on the other hand can allow the fluid to accelerate and shoot out of the end of the path. With the scene attached, you can get the effect by setting follow speed to 160, pull to 300 and rotation to 50
                  ahhh thanks very much for sorting that .. will be in time for the new project starting
                  Adam Trowers
                    Works perfectly
                    Adam Trowers
                      Hooray! Happy to hear that
