Regarding liquid simulations; Currently I am able to export the entire container with liquid, foam, splash to alembic particles but I haven't found a clean way to export the particle groups as separate alembics. It would also work if each particle group had a group within the alembic file so if they were still in the same file, they could be separated by group in another application.
One complicated method that might work would be to export each particle group to PRT, then load the individual PRTs into pflow, then export from pflow to alembic. But that's a bit of a process of course.
Wishlist item
Wishlist item
