Shader related improvements
This is a sticky topic.
  • Shader related improvements
    Almost all V-Ray materials and textures have Qt UIs now, which means faster UI drawing for smoother experience.
    VRayMtl: Implement energy compensation for the GTR BRDF
    Quote from Vlado's public post on the topic:
    "A long-standing problem with the VRayMtl material has been a certain darkening of the reflections for very low glossiness values; for some time we've been working to compensate this energy loss so that rough materials gracefully transition to a diffuse reflection distribution without becoming darker. This is done by approximating multiple reflection bounces of light between the microfacets of the material. The end result is a much more realistic appearance of rough metals and other reflective surfaces."
    Mind that it will be on by default for new materials, but for existing ones it's off to keep the consistency. You need to switch the option manually in MaxScript if you want to test it on old scenes (.option_gtrEnergyCompensation).
    VRayMtl: Improved SSS translucency mode of VRayMtl
    New implementation of the SSS mode that is faster to render and deals with faceting of low-poly objects. Again - on by default for new materials, but off for existing to keep the consistency. You need to switch the option manually in VRayMtl / Basic parameters / Illumination
    VRayMtl: Add Thin Film rollout in VRayMtl
    New additional layer for the VRayMtl. Good for doing soap bubbles and oil spills.
    VRayTriplanarTex: "Use displaced surface" option in VRayTriplanarTex for diffuse
    Ability of the V-Ray triplanar texture to work better with displaced surfaces by choosing the projection based on the original undisplaced points. This allows much easier setup of materials that use triplanar mapping for displacement as well.
    And a lot more ..
    Peter Matanov
    Chaos
    Really cool features. I was looking for Thin Film in new version and here it is
    AMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
    2D | 3D | web | video
    jiri.matys@gmail.com
    https://gumroad.com/jirimatys
    https://www.artstation.com/jiri_matys
    https://www.youtube.com/channel/UCAv...Rq9X_wxwPX-0tg
    https://www.instagram.com/jiri.matys_cgi/
    https://www.behance.net/Jiri_Matys
    https://cz.linkedin.com/in/jiří-matys-195a41a0
      Waiting for your tests results then
      Peter Matanov
      Chaos
        Does this affect the entire scene, or selected object's materials or somesuch?
          This is a property of VRayMtl, so you can change it for the materials you want.
          Peter Matanov
          Chaos
            Is Directional the old version and Uniform the new one?
            Not sure how to interpret this.
              Uniform is the new one.
              Peter Matanov
              Chaos
                is there somewhere in the docs some images or references of the differences?
                  I've uploaded here a contact sheet (zoom in 1:1, it's massive in size.) of one of the scenes we used to test, courtesy of Neal Biggs.
                  On average (meaning, +- 10%), in this scene, the new method (bottom row) took half the time as the old method.
                  The speed difference will be bigger the more lights are shining on the shader.
                  Lele
                  emanuele.lecchi@chaos.com
                  Disclaimer:
                    "VRayMtl: Add Thin Film rollout in VRayMtl" anyone managed to figure out what the settings should be for a Soap Bubble?
                      Here you go - soap.zip
                      Peter Matanov
                      Chaos
                        anders
                        result, and 2 options, with and without thin-walled set on basically (bubble on the left is a VraySphere, bubble on the right is a Sphere with a very small shell modifier on)
                        I haven't had any luck getting maps to work with Thin Film Thickness however - no matter what value i set a VRayColor at (0, 1, 10, 100, 500, 1000) in any channel i get the same result as 0 nm thickness, maybe this is a bug matanov ?
                        i also tried with gradient ramps, output node etc. all the same.
                          Originally posted by nicklas_byriel View Post
                          anders
                          Seems as bug to me too. I started thread about it some time ago but still no good answer on this one. Thread here:
                          https://forums.chaos.com/forum/v-ray...-new-thin-film
                            Yes, the map is not working in this build. We'll release a new one soon.
                            Peter Matanov
                            Chaos
                            • #15
                              Nice! Thanks for clearing that up, looking forward to play around with it with maps
