VRay 6 GPU Rendering wont detect or use GPU!
  • VRay 6 GPU Rendering wont detect or use GPU!
    I have the desired driver installed, 407.09, and the render will not render in RTX mode.
Name:	Screenshot 2022-05-03 101022.png
    I do in fact have a 3080 installed, and this *does* work with VRay 5.
Name:	Screenshot 2022-05-03 100953.png
    CUDA mode also does not detect or use the GPU, only the CPU as it detects only one device.
Name:	Screenshot 2022-05-03 101302.png
    What the heck.
    Hey HowardDay ,
    This is a limitation of today's build, it will be fixed in tomorrow's nightly. I'm testing a temporary fix at the moment, then eventually we will have a whole new UI in the upcoming weeks. It will be part of Max's UI
    We have a new device manager in V6, the idea is to be able to select which devices is used for denoising/rendering/priority respectively. I talk about this limitation in the V6 GPU thread here
    In my testing if you have set a separate device for the AI denoiser for Look-Dev this gives double the performance for IPR. Also setting the priority per device is very helpful
    About Max's standard light projection, there is a GPU implementation is in place in Maya and SketchUp plugins. Devs will get back to this soon on Max
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
      It is possible to set this manually for now using an environment variable, until tomorrow's build
      Click image for larger version  Name:	Screenshot_34.jpg Views:	0 Size:	148.8 KB ID:	1146965
      In my case here, my 3090 will be used for rendering only
      Muhammed Hamed
      chaos.com
        Thanks, Muhammed! That worked a treat. Out of curiosity, when should we expect to be seeing updated nightlies? So far there's just been the one, from last week. Do you expect to see that start updating with increasing frequency?
        Thanks again!
        Howie
          New beta build is expected for tomorrow.
          Peter Matanov
          Chaos
            New Beta build is live, you will be able to set the GPU devices like before, and it has all code changes for the new device manager. What is left is the UI which is WIP in progress, it comes out soon
            Best,
            Muhammed
            Muhammed Hamed
            chaos.com
              Best,
              Muhammed
              Yeah, now the Environment variable doesn't work. I've got the latest nightly, and I've done both the env variable, and selected the gpu in the UI, rebooted/restarted after doing so and it makes no difference. it can't find the card.
Name:	Screenshot 2022-05-16 100057.png
              What am I missing?
                Hey HowardDay
                it works here without issues, you can delete this environment variable to be sure and stick to Max's UI
                Can you write me your build number? sure it is the second beta from 10th of May?
                Best,
                Muhammed
                Muhammed Hamed
                chaos.com
