I rendered a project in 6 and it came out slower than in 2020 Next rendering. 13mins vs 16mins approx.
Rendering slower than Next
You can use the support form at https://support.chaos.com/hc/en-us/requests/newYavor Rubenov
V-Ray for 3ds Max developer
Hello again.
So, i tested the file you sent, and indeed it renders a good 15% slower than with Next for pretty much exactly the same noise level.
This is chiefly due to the change to the LightCache made as of V.5, which however isn't of much help in your case.
I took the liberty to update the scene setup to a modern one, which doesn't involve the IRMap (essentially an old method to get a smooth GI solution), but uses the Denoiser instead (which conditionally smooths the image).
The result is a render with 20% lower Noise Level, but a render time about four times lower than in V-Ray Next.
Let me know what can be shared publicly, if anything at all, or if you preferred i got back to you via E-Mail with the various samples.Last edited by ^Lele^; 12-06-2022, 07:30 AM.Lele
emanuele.lecchi@chaos.com
Disclaimer:
