Has the sun disk disappeared from V-Ray GPU again?
  • Has the sun disk disappeared from V-Ray GPU again?
    I can't see it any more in the latest version, at least when using clouds, and regardless whether the sun is obstructed by clouds or not.
    Check my blog
    Can you attach a simple scene? Work fine here.
    Peter Matanov
    Chaos
      If the sky map is in a dome, the sun disk won't show up, it works fine on CPU.
      Lele
      emanuele.lecchi@chaos.com
      Disclaimer:
        Isn't putting the sky map in a dome the recommended workflow (at least for speed)?
        Website
        https://mangobeard.com/
        Behance
        https://www.behance.net/seandunderdale
          Yes, it most definitely is.
          Lele
          Disclaimer:
            Ok. I put the sky map in a dome. This explains that. Should the dome then be made invisible?
            Check my blog
              Eh yes, you could get around it by making the dome invisible, duplicating the sky map in the BG, and then turning the environment GI override to black (so you don't get double sky lighting).
              It should be fixed, though.
              Lele
              Disclaimer:
                I got confused by the "again" part in the thread title, because I don't remember seeing it in a Dome light in GPU before.
                Peter Matanov
                Chaos
                  trying now.
                  Check my blog
