Vray FUR on backside
  • Vray FUR on backside
    Is that possible to apply Fur on the backside of the object? for eg, if i am having a plane - with double sided material. Applying fur is displaying on front side only. can we able to apply for back side also ?
    Regards,
    Gopinath.
    VRay Fur is generated only on the front faces. You will need to add a shell to your geometry or make a very thin box. Then you can exclude the thin side faces for the fur generation.
    Martin Minev | chaos.com
      Hello Martin,
      Thanks for your reply.
      Will try as per your suggestion.
      Regards,
      Gopinath.
