Why denoise result is different using same rtx graphics card?
  • Why denoise result is different using same rtx graphics card?
    Same vrscene
    Machine 1
    Code:
    [VRay][Info] VDenoise: Using device 0: NVIDIA GeForce RTX 3080
    [VRay][Info] VDenoise: Driver version 528.49
    [VRay][Info] VDenoise: OpenCL compiled successfuly
    [VRay][Info] Render elements to be denoised:
    [VRay][Info] RGB color
    [VRay][Info] Alpha
    [VRay][Info] Denoising complete in 1.14 s
    Machine 2
    Code:
    [VRay][Info] VDenoise: Driver version 511.17
    [VRay][Info] Alpha
    [VRay][Info] Denoising complete in 0.73 s
    Machine 1 result image is better than machine 2. why? Driver version?
    App sdk version appsdk-win_qt5-nightly-vray_v5.20.24-20230218
    ​OS windows server 2022 standard
    Probably the final images before denoising were different.
      stanislav.kirilov
      Two machines are running the same program with the same config(bucket rendering)
      Machine 1 cpu: AMD EPYC 7763 clockspeed 2.5 GHz
      Machine ​2 cpu: AMD Ryzen 7 5800X clockspeed ​ 3.80 GHz
      Will the clockspeed influence the result image?​
      And can I denoise the image many times?
