Many different hardware factors not displayed - additional features.
  • Many different hardware factors not displayed - additional features.
    I was wondering if you could add additional system hardware info in future releases:
    1. Not seeing win 11 at all.
    2. Pcie version (v3.0, v4.0, etc.)
    3. Onboard ram.
    4. Overclocking
    5. Average results
    6. Sortable fields.
    7. motherboards, bios versions, nvme types, SSRs,PCIe lane availability, etc. perhaps a way to integrate something like cpuid or hwinfo
    I mention this because I believe the results (showing the high-end) are extremely skewed. There’s definitely crypto miners using this tool and overclockers which don’t necessarily represent average results. While the tool is useful, it’s difficult for an average person focusing on stability (not overclocking) to determine if their hardware is within a certain acceptable range.
    Hi jujubee
    This is possible now, a colleague of mine showed me in the past but I cannot remember now. I will ask again and get back to you
    But yeah this should be easier to find.
    This will not be possible and probably makes things complicated
    PCIe Gen 4 x4 is the same speed as PCIe Gen 3 x8 , so the generation alone doesn't tell the whole story.
    And depending on the number of devices connected, this link speed will change. And this depends on the platform and board
    There is also PCIe Gen 5 with some Z690 boards now, this will be a complicated task to do
    I have done some PCIe bandwidth testing for V-Ray GPU, let me know if you are interested. I can share the data
    3. Onboard ram.
    Do you mean system memory?
    It should be possible yes, although it doesn't really tell much(unless we report additional information like memory channels, frequency and latency, then this becomes very complicated)
    4. Overclocking
    Not possible,
    There is no easy way to tell if a CPU or GPU are overclocked. For GPUs some 3rd party cards come factory overclocked and you will have many vendors competing like Asus, MSI, Zotac..etc
    They all try to push GPU frequency higher, there is no standard really to match against and tell if there is Overclocking
    For CPUs it is a similar story, even the reported frequency is not gauranteed to be accurate. With PBO, AMD CPUs will boost higher as long as temperatures are within limit
    5. Average results
    It is possible now,
    Click image for larger version  Name:	Screenshot_77.jpg Views:	0 Size:	35.0 KB ID:	1141805
    Click image for larger version  Name:	Screenshot_78.jpg Views:	0 Size:	18.6 KB ID:	1141806
    5. Average results
    Possible now to some extent as well
    Too much work honestly, HWinfo and/or GPUz exist and are free
    PCIe lane availability is something very hard to report, most softwares now are not able to verify correctly
    What you can do is check a device's link, like a GPU or an NVMe
    I agree that Extreme results are misleading, hence why we added the average results
    Extreme results are indeed overclocking(but not miners)
    Mining hardware will have bad benchmarks actually, as miners will undervolt it to save electricity.. this undervolting is quite extreme and mostly through a custom bios
    Thanks for the feedback, we will consider for the upcoming versions
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
      Interesting. I seen a few results in which someone or some company had machines with 8+ (even 12) GPUs and all I could think was that it was perhaps someone using their rigs to mine. I just don't even know how it is possible to run this many cards.
        Many consumer boards could equip up to 7 GPUs, examples are Asus X299 WS Pro and Asus Pro WS WRX80E
        Each of these will be able to equip 7 GPUs natively and they will run at the proper bandwidth, the second board will run all GPUs at x16 PCIe Gen 4
        For this to work, you need to use riser cables or you watercool the GPUs(removing the massive air cooling shrouds)
        On another note, I built 8 and 10 GPU servers in the past. They exist and are fairly common in GPU rendering
        Supermicro offers many boards and cases that equip 10 GPUs natively.. it uses dual Xeon CPUs and provides x16 bandwidth as well
        More than 10 GPUs, you will need to use clusters. I have seen up to 18 GPUs per machine using clusters
        Anything more than 4 GPUs will not work out of box and will require bios tweaking
        This is very different than mining setups, where PCIe bandwidth don't matter at all. Mining rigs are much cheaper than this
        Best,
        Muhammed
        Muhammed Hamed
        chaos.com
          I have riser cables and had done this with my current intel board. Also watercooled my previous cards.
          It's something I got out of due to stability and power requirements. I had a difficult time trying to find reasonably priced riser boards for a separate chasis. It did seem like the majority of them and info years back were mostly geared towards crypto.
          It's something I had brought up with Vlado a long time ago and I remember he was curious then ran some experiment. It must have been in the infancy of Vray GPU rendering.
            Yeah, it is a bit different now
            Riser cables or watercooling can be very reliable at the moment. So 7, 8 and 10 GPU machines are not odd on the GPU Rendering community. I had access to 2 of these when I worked at Carlex a few years back
            7 GPUs with Riser cables is possible, and kind of easy to pull off using Riser cables and a variety of boards like the Asus X299 Pro WS.. the setup itself is not expensive(without the cards)
            Best,
            Muhammed
            Muhammed Hamed
            chaos.com
              Any external case recommendations or even extension boards to house the cards? I kept my older long riser expansion cables.
                Hi Muhammed_Hamed
                Originally posted by Muhammed_Hamed View Post
                ...I have done some PCIe bandwidth testing for V-Ray GPU, let me know if you are interested. I can share the data
                I would be interested in your data!
                We have quite a bunch of GPU rigs, most of them have their GPU's on x1 risers.
                The pure renderpower is fine and the GPUs are excellent to cool on risers.
                The downside is that building the light cache for example, or using a denoiser makes a lot of busload and slows down the rendertime in comparisson to onboard GPUs.
                  Hello NotHuman
                  Yeah, exactly
                  You need x16 shielded risers for this to be optimal, it will be identical to using the PCIe lane on the board. You will find some fancy Gen 4 risers now as well in case you have high-end Ampere GPUs
                  Yeah this is why people use risers, they offer really good thermal performance as you can space the cards in a GPU rack
                  And for something like the X299 Pro WS, you can equip up to 7 GPUs on this board using risers
                  And yes, the Render power is fine once the data is loaded in the GPU memory. should be identical to running natively
                  In my testing, x8 Gen 3 is the same speed as x16 Gen 3. This bandwidth is usually enough for GPU rendering
                  Then with x4 Gen 3 you will start losing performance.. like 5-10% depending on how heavy the scene is
                  x1 is much slower, specially with something like a 3090/3080 .. heavy scenes will take a while to load into GPU memory before the actual rendering starts
                  x4 Gen 4 is similar to x8 Gen 3 and so on
                  Let me know if you have questions
                  Best,
                  Muhammed
                  Muhammed Hamed
                  chaos.com
                    Sorry I missed on this question
                    I use the standard mining racks(for 4 GPUS or more), they are cheap and available everywhere. And sometimes I just use my disk
                    Then you have more expensive options like this one here https://www.nanoxiausa.com/products/...mid-tower-case
                    Best,
                    Muhammed
                    Muhammed Hamed
                    chaos.com
