Multi-gpu not really faster or???
  • Multi-gpu not really faster or???
    One thing I don't understand in the v-ray benchmark results is that a single 1080 ti is almost as fast as 4 ou even 8 1080 ti. Could it be a mistake in the listing or is V-Ray not able to use all gpu on some systems?
    see: https://benchmark.chaosgroup.com/gpu...string=1080+ti
    21 sec for a single 1080 ti at the bottom... then 21 for 4x1080 ti.
    Then some x4 1080 ti gives 17.774 sec while x8 1080 ti gives only 16,6...
    I just bought 8 1080 ti and I'm wondering if I should put them all in the same system (I have 6 gpu slot but was thinking using pci-e splitters) or distribute them in many system and use DR. I would like to know before ordering another power supply and the risers etc.
    3 00:16.601 Intel(R) Xeon(R) CPU E5-2630 v4 @ 2.20GHz x40, GeForce GTX 1080 Ti 11264MB x8 1
    4 00:16.669 Intel(R) Core(TM) i7-6950X CPU @ 3.00GHz x20, GeForce GTX 1080 Ti 11264MB, TITAN X (Pascal) 12288MB 1
    5 00:17.592 AMD Ryzen 7 1700X Eight-Core Processor x16, GeForce GTX 1080 Ti 11264MB, Quadro GP100 16291MB x2 1
    6 00:17.774 Intel(R) Core(TM) i7-5930K CPU @ 3.50GHz x12, GeForce GTX 1080 Ti 11264MB x4 1
    7 00:17.926 Intel(R) Core(TM) i7-6950X CPU @ 3.00GHz x20, GeForce GTX 1080 Ti 11264MB x3, TITAN X (Pascal) 12288MB 1
    8 00:18.652 Intel(R) Core(TM) i7-5820K CPU @ 3.30GHz x12, GeForce GTX 1080 8192MB, GeForce GTX 1080 Ti 11264MB x2, GeForce GTX 980 Ti 6144MB, GeForce GTX TITAN X 12288MB x2, TITAN X (Pascal) 12288MB x2 1
    9 00:19.194 Intel(R) Core(TM) i7-5960X CPU @ 3.00GHz x16, GeForce GTX 1080 Ti 11264MB x4 1
    10 00:19.513 Intel(R) Core(TM) i7-6950X CPU @ 3.00GHz x20, GeForce GTX 1080 Ti 11264MB x2, TITAN X (Pascal) 12288MB x2 1
    11 00:19.669 Genuine Intel(R) CPU @ 2.80GHz x32, GeForce GTX 1080 Ti 11264MB x4 1
    12 00:19.856 Intel(R) Core(TM) i7-6900K CPU @ 3.20GHz x16, GeForce GTX 1080 Ti 11264MB x4 1
    13 00:19.974 Intel(R) Core(TM) i7-6950X CPU @ 3.00GHz x20, GeForce GTX 1080 Ti 11264MB x4 1
    14 00:20.831 Intel(R) Xeon(R) CPU E5-2680 v4 @ 2.40GHz x56, GeForce GTX 1080 Ti 11264MB x4 1
    15 00:21.132 Intel(R) Xeon(R) CPU E5-2687W v4 @ 3.00GHz x48, GeForce GTX 1080 Ti 11264MB x4 1
    16 00:21.613 Intel(R) Xeon(R) CPU E5-2683 v3 @ 2.00GHz x56, GeForce GTX 1080 Ti 11264MB 3
    __________________________________________
    www.strob.net
    Explosion & smoke I did with PhoenixFD
    Little Antman
    See Iron Baby and other of my models on Turbosquid!
    Some RnD involving PhoenixFD
    Hello,
    The results at 16th place seem strange a bit - two of the 3 results have comments and the comments mention Quad 1080Ti - so I would guess that there is some issue with the results display.
    Yavor
    Yavor Rubenov
    V-Ray for 3ds Max developer
      Ok yes I didn't know we could read comments by hovering mouse over the text bubble. So they are four GPU. I'm still surprised that 8 gpu only gain 1 second but maybe with a more difficult scene it would give a bigger difference.
      www.strob.net
      Little Antman
        We had a problem with 1.0.5 version of V-Ray Benchmark and it didn't provided information about GPUs count. This is fixed in 1.0.6. Database at https://benchmark.chaosgroup.com is fixed, too.
        So now you may see correct results for multi-GPU configurations. Please, check again.
          Hi Strob, I was noticing that too. I'm wondering if at that point the PCIe speed is diminishing enough (probably to x1/x2) to support that number of cards. In a 4 way setup you're maintaining at least x8/x8/x8/x8.
            It may be a problem due to configuration in the bios and or windows related problem. My guess is that we son't have that problem with Linux. Righ now I have only 2 cards in the same system but I have a total of 8 cards that I will try to test test all in the system soon and will compare it to putting the same cards inside of many different system using DR.
            www.strob.net
            Little Antman
              That's very possible. From my internet travels I've seen instructions about hacking registries and bios to get more than 4 cards recognized. Please let us know how your 5+ card solution turns out.
                Glad I've caught this early on - but am wondering does the fault lie in the benchmark software, or is it truly an issue with hardware / bios etc limitations being hit ?
                From memory, I was seeing scalable results both from the earlier versions of the benchmark software (jumping from 2 to 4 1080 ti's) and with my own project scenes.
                I've just built an open rig frame and purchased all the risers etc so will be following this thread carefully before making any further hardware purchases (my mobo can support up to 7 GPU's).
                Jez
                3DS Max 2023.3.4 | V-Ray 6.10.08 | Phoenix FD 4.40.00 | PD Player 64 1.0.7.32 | Forest Pack Pro 8.2.2 | RailClone 6.1.3
                Windows 11 Pro 22H2 | NVidia Drivers 535.98 (Game Drivers)
                Asus X299 Sage (Bios 4001), i9-7980xe, 128Gb, 1TB m.2 OS, 2 x NVidia RTX 3090 FE
                ---- Updated 06/09/23 -------
                  Usually V-Ray GPU scales okay with multiple GPUs. Could be V-Ray Bench thing. Will check.
                  Best,
                  Blago.
                  V-Ray fan.
                  Looking busy around GPUs ...
                  RTX ON
                    Best,
                    Blago.
                    Cool to know.
                    And JezUK, cool your open rig! I considered those handy aluminium extrusion and then I remembered I had some electrical panels (kind of metal boxes) lying in my shed. I am building a 8 gpu rig in an enclosed case with those panels. Also using risers including a special one that split one pci into 4.
                    www.strob.net
                    Little Antman
