benchmark 5 doesn't start
    Hi daniel.taskoff,
    Benchmark 5.01.00 just exits after briefly showing the splash screen for me.
    Same log as post #3 above:
    Code:
    [benchmark] got args:
    [warning] Couldn't get information about hardware-accelerated GPU scheduling
    V-Ray Benchmark: FatalError "Couldn't get frequency"
    V-Ray Benchmark: exit(1)
    TypeError: Cannot read property 'emit' of undefined
    at ChildProcess._0x1685b3 (C:\Users\myusername\AppData\Local\Temp\V-Ray Benchmark\resources\app\src\main.js:1:6855)
    at ChildProcess.emit (events.js:182:13)
    at maybeClose (internal/child_process.js:962:16)
    at Process.ChildProcess._handle.onexit (internal/child_process.js:251:5)
    I ran the 2 powershell commands, the first runs successfully, the 2nd returns the same error as in post #8 above
    I also reset the performance counters by executing the 2 commands you supplied.
    I am trying to run the benchmark on Windows 7 Pro 64 bit with a RTX 3060.
    The GPU is a LHR variant so I wanted to double check its performance against non LHR variants for my own sanity!
    Any other ideas what could cause the benchmark to not launch?
    Olly
    Set V-Ray class properties en masse with the VMC script
    Follow me for script updates: @ollyspolys
      Hello olly, I'm sorry, but we do not support Windows 7 anymore (V-Ray 5 Benchmark system requirements, and V-Ray 5 system requirements).
        No problem - I figured that would probably be the case!
          done lodctr /r and %windir%\SysWOW64\lodctr /r still cant run
            I have the same problem! The interface loads fine, but as soon as I click the button to run the CPU benchmark, I get an error which says "[benchmark] FatalError "Scenes have been changed!" . Log file is attached.
            Aleksandar Mitov
            www.renarvisuals.com
            office@renarvisuals.com
            3ds Max 2023.2.2 + Vray 7
            AMD Ryzen 9 9950X 16-core
            64GB DDR5
            GeForce RTX 3090 24GB + GPU Driver 565.90
            • #21
              Alex_M, your problem is unrelated to the others in the thread.
              Do you have sufficient space on the drive, where %temp% is located? If so, try deleting %temp% after stopping any running V-Ray Benchmark instances.
              • #22
                Hi Daniel,
                I deleted the "V-Ray Benchmark" folder in %temp% and now the benchmark works fine. Thanks!
                Aleksandar Mitov
                64GB DDR5
                • #23
                  Hello everyone,
                  I also can't run Benchmark 5. On two different computers. Zbook Studio 4G i7 6gen m1000m 32GB win7 and Lenovo Legion 5 Ryzen 7 5800H, 16GB, RTX 3070 win 10. On both of them the message "an error has occurred" appears. Log file from Legion:
                  [info] Loading plugins from "C:\Users\User\AppData\Local\Temp\V-Ray Benchmark\resources\app\bin/plugins/vray_*.dll"
                  [benchmark] Started V-Ray Benchmark 5.02.01
                  [benchmark] Getting setup
                  [info] 74 plugin(s) loaded successfully
                  [info] Finished loading plugins.
                  [warning] Improve your performance by upgrading your driver from version 527.99 to 536.40.
                  [benchmark] V-Ray Benchmark 5.02.01 [c603de540ac4ba99ea6fd563fac59a05c94430e0]
                  [benchmark] Microsoft Windows 10 Home
                  [benchmark] V-Ray 5.00.20 [fe244a33]
                  [benchmark] NVIDIA driver: 527.99
                  [benchmark] [0]: AMD Ryzen 7 5800H with Radeon Graphics
                  [1]: NVIDIA GeForce RTX 3070 Laptop GPU 8191MB
                  [benchmark] C:\Users\User\AppData\Local\Chaos/benchmark.refresh: openBinaryFile: does not exist (No such file or directory)
                  [benchmark] Opening status socket
                  [benchmark] Status socket opened
                  [benchmark] Opening image socket
                  [benchmark] Image socket opened
                  [benchmark] Starting a render
                  [benchmark] Starting a V-Ray GPU RTX render
                  [benchmark] Scenes have been changed!
                  [benchmark] The impossible has happened: Idle
                  • #24
                    Hello, krzysztof_szpakowski, did you try deleting %temp%/V-Ray Benchmark? Your error means, that either the scenes have been modified, or they haven't been extracted properly. Do you have enough space on your hard drive?
                    • #25
                      i have the same issue wont even let me install the software i get this window popping up
                      Click image for larger version  Name:	Capture.jpg Views:	0 Size:	50.5 KB ID:	1195600
                      slightly different error when i right click on exe and run as administrator
                      runing windows 10
                      thanks
                      matt
