V-Ray Next Update 3 available for download
  • #16
    Originally posted by super gnu View Post
    cool! nice fat update. cant wait to hear more about the new features.
    just a quick question, i note you specify driver 441.28 for RTX support. do you know if this driver revision still supports 2+ pairs of gpus in nvlink mode? it was suggested that at some point this ability was going to disappear.. It would be nice if there was at least one driver revision where both RTX and multiple nvlink pairs was supported!
    also very interested in this, otherwise will stay on current drivr that supports nvlink
    • #17
      Originally posted by Vizioen View Post
      It's funny you've "excused" the name of the VrayHDRI map a few times before, and I've yet to find a person in the office that uses VrayHDRI for anything else than .hdr or .exr files for lighting, even though I've been almost preaching the use of a VrayHDRI due to it's better filtering among other things. I don't know why but somehow because of the name (I think it's psychological) they fail to use it instead of the standard max bitmap.
      On the topic of the update: Thank you Chaos for your hard work. Although I feel a bit left in the cold, and I don't want to sound ungrateful or arrogant but I feel like there's nothing groundbreaking coming to Vray in terms of achieving better faster results visually for me, speaking as a digital artist, in the last year or 2.
      I'm not sure but I feel there's a lot of features that could really speed up our creation workflow by a lot and I know (or hope) it's being worked on but it's just soooo hard to wait
      VFB 2.0 (lightmix,...)
      Stochastic Texturing
      Fixing Bump
      UVW Randomization with a map
      Material Override 'preserve' option
      Better material preview (together with the material library even)
      Better color mapping options
      To only name a few of the wishes of this community (well at least the ones that post here), I'm sure you're tired of reading these by now
      Anyhow thanks again for the update!
      Yeah, I kind of had the same reaction to this release. Very grateful for the hard work of the team but sorry to see UX taking a bit of a back seat again. I understand different users will have different priorities. For some the RTX integration will be amazing I'm sure! But for us if it's harder to get to the look you want due to lacking interface features (even if the rendering goes faster than comparable renderers) getting from point 'A' to point 'B' is ultimately going to take longer when it comes to total time spent.
      • #18
        Amazing as always. Thanks so much for the RTX support! Couldn't wait for this day to come!
        • #19
          Fixing Bump
          What do you mean?
          Peter Matanov
          Chaos
          • #20
            (*) VFB: Enable setting of the render region via MAXScript outside the default resolution before rendering;
            Does this mean that OverScan rendring is now possible on the V-Ray side?
            What is "default resolution"? Currently set rendering resolution?
            OakCorp Japan - Yuji Yamauchi
            oakcorp.net
            v-ray.jp
            • #21
              (*) VRayALSurfaceMtl: SSS is not computed for materials seen through glossy refraction;
              (*) VRayStochasticFlakesMtl: Stochastic flakes are not visible through glossy refraction;
              Is this a Bug Fix?
              Or is it not calculated to reduce rendering time?
              oakcorp.net
              v-ray.jp
              • #22
                Originally posted by flat View Post
                Is this a Bug Fix?
                Those are bug fixes, they were missing when looked through glossy refractions and now they should work as expected.
                Peter Matanov
                Chaos
                • #23
                  Thank you for the awesome work you put into this update guys, really appreciate everything that goes into it.
                  Unfortunately I just tested out the RTX integration on a quick test scene and it actually added 2 minutes and 20 seconds, running on a 2080ti with the new drivers. Ill test it out on more scenes I have and hopefully this isnt replicated.
                  Cheers
                  • #24
                    Thanks for the update. Why no video on your Youtube channel showcasing the new update? Usually you post such videos. It would be great to see what's new and improved at a glance.
                    Aleksandar Mitov
                    www.renarvisuals.com
                    office@renarvisuals.com
                    AMD Ryzen 9 9950X 16-core
                    96GB DDR5
                    • #25
                      I know, I know There are a lot new nice things but check the list then try to market them in a video and you'll see why
                      Peter Matanov
                      Chaos
                      • #26
                        Thanks. Maybe I'll just install it and try it out.
                        Aleksandar Mitov
                        96GB DDR5
                        • #27
                          Cheers
                          I have unfortunately experienced the same with an rtx 2080 testing progressive and bucket... but still really nice work on fixing everything else.
                          • #28
                            Keep in mind that the first time you launch the RTX engine (per new build/driver) you wait 45 seconds on average for kernel compilation per GPU.
                            Peter Matanov
                            Chaos
                            • #29
                              Our KristinIvanova was reminding me that our excellent docs team has already prepared a page to better showcase the new filtering mode.
                              Go here for all the juicy details.
                              Lele
                              emanuele.lecchi@chaos.com
                              Disclaimer:
                              • #30
                                Cheers
                                The first run is always slow for scene compilation, it should be fine with more runs
                                in my test scenes there have been a massive speed boost with RTX on
                                Muhammed Hamed
                                V-Ray GPU product specialist
                                chaos.com
