Just a very quick note. After installing update 3, I did a test render, using a previous project. Everything went well AND a little faster too, only a couple of seconds but hey, any gain in speed is alwasys welcome.. Anyway, I noticed odd behaviour, when clicking on the stop button. Usually the VFB would just stop rendering and the Stop button would then be greyed out.. Now when I press stop, it closes the VFB and I have to open it again, from the Frame Buffer tab in the Settings dialog, not a disaster, but a bit annoying. Any ideas
V-Ray Next Update 3 available for download
Interesting. I've just tried this and it doesn't happen for me here. I tried with both "stop" buttons, the one in VFB and the one in the render progress window.Aleksandar Mitov
www.renarvisuals.com
office@renarvisuals.com
AMD Ryzen 9 9950X 16-core
96GB DDR5
I'm using Max 2014, yes I know an old version, but I'm so used to it and have it al set up just as I like it. Many have tried to get me to upgrade, but I'm trying very hard, not to.. I guess it could be my version of Max, but I don't see why.. One thing I have not tried yet, is restarting the computer. As I say I only just installed V-Ray and apart from this odd glitch, it's working well. I'l give a reboot a try and get back and let you know if it solved the problem or not.
EDIT... OK restarted the computer, Started up Max, loaded the exact same scene. Started IPR. waited for it to start rendering, then hit stop in the VFB and the VFB immediately closed..
I then opened up the VFB and hit Render in the Render Setup dialog box, waited for it to stat rendering and hit Cancel. The render stopped and the VFB remained open.
Rebooting had no effect, so definitely a bug, but what is causing it, V-Ray Next update 3 or Max 2014, that I don't knowLast edited by andy51; 24-11-2019, 03:53 PM. Reason: Updated with result of rebooting and retesting, to see if problem was solved
Originally posted by andy51 View PostI'm using Max 2014, yes I know an old version, but I'm so used to it and have it al set up just as I like it. Many have tried to get me to upgrade, but I'm trying very hard, not to.. I guess it could be my version of Max, but I don't see why.. One thing I have not tried yet, is restarting the computer. As I say I only just installed V-Ray and apart from this odd glitch, it's working well. I'l give a reboot a try and get back and let you know if it solved the problem or not.
Rebooting had no effect, so definitely a bug, but what is causing it, V-Ray Next update 3 or Max 2014, that I don't knowLast edited by matanov; 25-11-2019, 10:30 PM.If it was that easy, it would have already been done
Peter Matanov
Chaos
The default render time is now 0.... awesome! That 1 minute always confused me why it was set to that.Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- ​Windows 11 Pro
- Likes 2
Originally posted by slizer View Post
It's a bug that affects old Max version, it will be fixed.
The exr multipart option is supported now for GPU!! THANKS!!!
Found out by accidentcan't find it in the changelog.
Also, like everyone I'm totally blown away by the power of the RTX implementation!
Awesome release!German guy, sorry for my English.
- Likes 1
Hi, thank you for the update, i am not using RTX, can I update to this version?Best regards,
Jackie Teh
3ds Max 2023, V-Ray 7 Update 1 [7.10.00 build 00000]
AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
Website: https://www.sporadicstudio.com
Email: info@sporadicstudio.com
YouTube: https://www.youtube.com/c/SporadicStudio
Originally posted by jackieteh View PostHi, thank you for the update, i am not using RTX, can I update to this version?If it was that easy, it would have already been done
Peter Matanov
Chaos
- Likes 1
Thank you for the update!
One question about this feature:
(*) VFB: Add "Save in image" option to OCIO color corrections, to save the corrected image;
How can I have access to that tickbox in maxscript? There's nothing about it in the manual (https://docs.chaosgroup.com/display/...ogrammatically)
Thanks!
