Build 3.10.03 available for download
  • Build 3.10.03 available for download
    Hello,
    We uploaded a new build on the website, version 3.10.03. This mainly fixes an issue with the Extension 2/SP3 builds of 3ds Max 2015 on DR render servers, but it also has a few smaller fixes:
    Build 3.10.03 (official) (12 January 2015)
    Modified features:
    (*) V-Ray RT GPU: Added support for VertexColor texture;
    (*) V-Ray RT GPU: Basic support for rendering VRayDirt texmap;
    (*) VRayMetaball: Added support for MaxScript vector color source;
    (*) VRayProxy: Force first map channel option disabled by default;
    (*) .vrmesh viewer: Added a slider controlling the point size of particles;
    (*) .vrmesh viewer: Enabled OpenGL point smoothing only when the point size is greater than 1.0;
    Bug fixes:
    (*) V-Ray: Fixed 3ds Max 2015 with Extension 2 crash on remote DR hosts;
    (*) V-Ray: Fixed hairs smooth normals rendering with V-Ray Standalone;
    (*) V-Ray: Fixed MaxScript VFB functions not working when V-Ray RT set as production renderer;
    (*) V-Ray RT: Added export of GI ambient occlusion parameters;
    (*) V-Ray RT: Fixed export of "sample lookup" Irradiance Map parameter;
    (*) V-Ray RT: Fixed not exporting the default geometry type for objects with type set to Default in the V-Ray object properties;
    (*) V-Ray RT GPU: Fixed crash when UVW coordinates are invalid;
    (*) V-Ray RT GPU: Fixed crash with refractive overlapping faces;
    (*) V-Ray RT GPU: Fixed Light Cache loading on DR hosts;
    (*) VFB: Fixed crash caused by NaN output values with Curve color correction;
    (*) VFB: Fixed wrong time stamp when loading images from history;
    (*) VRayClipper: Fixed artifacts near the edges of intersection surfaces;
    (*) VRayHDRI: Fixed "Match Bitmap Size as Closely as Possible" 3ds Max option to work for VRayHDRI with Legacy Direct3D driver;
    (*) VRayHDRI: Fixed viewport preview not working for map channels differing from 1;
    (*) V-Ray RT: Fixed crash when disc light has VRayColor for texture;
    (*) V-Ray RT: Fixed issue with multiple disc lights with different colors rendering only the color of the first light;
    (*) VRayProxy: Fixed crash with displacement when no vertex normals are present;
    (*) ply2vrmesh: Fixed conversion from Alembic particles, that was causing crash during rendering;
    Thank you.
    The reported problem is fixed. (Legacy Direct3D driver)
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
      What does it mean? I thought that VrayProxy and displacement doesn't work together??
        Yes that is correct. In 3DSMax displacement is not supported on VrayProxies, but in V-Ray for Maya it is supported.
        Since with version 3.x V-Ray for 3DSmax comes with V-Ray Standalone, some bugs which are already fixed in V-Ray for Maya have to be ported into Standalone version that comes with 3DSMax.
          Oh boy that mean that there are now features in V-Ray for maya that we don't have in V-Ray for 3ds max???
          By the way when will you make V-Ray for Houdini?
          __________________________________________
          www.strob.net
          Explosion & smoke I did with PhoenixFD
          Little Antman
          See Iron Baby and other of my models on Turbosquid!
          Some RnD involving PhoenixFD
            This will be corrected
            Unfortunately, I'm not able to answer this question.
            Tashko Zashev | chaos.com
              Hi Vlado
              Will this build work with max2016 ? regards J
                Mostly yes, but it's better to wait for a proper 2016 build.
